Go Back  Offshoreonly.com > Technical > Electronics
Stereo system question >
Old 04-24-2024, 07:04 AM
Originally Posted by xlint89
Or you can do something like this.
https://shop.wetsounds.com/WS-220-BT/
You can put 2 RCA from the head unit into it. Then it will split your signal to the appropriate amplifier. You can then control each "zone" as you wish
I think that is overkill for my little boat but totally bad ass! Not going to lie you got me thinking lol!
Joeyboost is offline
Old 04-24-2024, 08:48 PM
You wanted options/opinions..... There's lots of cool electronics out there now.
Not sure if you picked up on it, but that's also a blue tooth. So you can sync your phone to it.
xlint89 is offline
Old 04-25-2024, 01:24 PM
I saw that, I also saw the switch sized vol/channel/power selector which is bluetooth. Will that work with any head unit?
https://shop.wetsounds.com/WW-BT-RS/
Old 04-26-2024, 08:42 PM
It does say it can be used with any head unit that has aux inputs. I'd contact a dealer and see what they say.
xlint89 is offline
xlint89 is offline
Old 04-27-2024, 05:57 AM
Originally Posted by BBYSTWY
I'm partial to Memphis Audio as I have been a dealer for 15+ years...they make some really nice and compact stuff that is marine rated. Just another option. I have 4-8" speakers with 4-1" comp tweeters in my cockpit and 4-6.5" speakers in the cabin with 3-12" subs throughout running off 2-5 channel amps and 1 head unit in my boat.....It literally hurts your ears with it turned up especially the competition tweeters lol
Memphis Audio makes some excellent products for sure. I had some MOJO Pro tweeters in my old boat...those things were incredible.
Baja 252 Islander
bajaman is offline
Old 05-03-2024, 10:05 PM
I assuming that you are using the high pass crossover, stacking 2 speakers on each channel should a be just fine . High frequency’s like 90 hz and above aren’t going to strain the amp.
carnutsx2 is offline
