Outdrive stand and lift homemade no welding
#81
#82
i started a thread about mine in the Kryptonite section, guess I can put it up here also.
I went as cheap as I could with mine. All told I have $78 in it, not counting the welder of course. Bought the cheapest engine stand that harbor frieght had in stock, a square tongue jack from HF, and some 1x1 1/2" square steel tubing. used the measurements that someone else posted in this thread. Took a total of about 2 hours to completely assemble. I welded the fork on mine at a slight reaward angle, so when the weight of the drive is on it, it is just about level. The whole upper assembly is removable by pulling a pin out.
I am considering putting pneumatic wheels on it, but right now, it works perfectly.
If you have never used a stand to R/R a drive, I owuld highly recommend it. I can install my drive with the ITS shaft in under 5 minutes, and that is including the time it takes to tighten all six nuts. It is fantastic.
![](http://i690.photobucket.com/albums/vv262/macattack119/downsize-2.jpg)
#84
Are we having fun, yet?
Thanks TF! Like I have said before, I put things together like this to make my life easier. It isn't perfect, but it works great. I have loaned mine out a bunch......
Philm - I have about the same $$$ in mine.
Jay
Jay
#85
![Smile](/forums/images/icons/icon7.gif)
this one looks great think i am going to coppy it like the simple way it it goes up and down thanks for pic paul england sent this befor i got to all the other threads praising you idea seems every body likes your one my check is already in the post
#86
#87
I've been trying to duplicate the Yardarm for a while. I made a drive stand like the everyone else, but my problem has always been getting the correct horizontal & vertical alignment of the drive to slide it in. So I tore down the old drive stand and created a new one from a transmission jack. This give me a 3 dimension adjustment so I can just slide it back in with now issues. Cost: $140.00
![](http://i276.photobucket.com/albums/kk26/bert4332/102_1849.jpg)
![](http://i276.photobucket.com/albums/kk26/bert4332/102_1850.jpg)
#88
https://picasaweb.google.com/32veloc...eat=directlink
heres one I threw together,, the head will tilt/pivot on the center bolts it goes up and down using socket and ratchet , breaks down for storage, if anyone needs any info just reply or pm. I have about $16 in it for casters ,everything else came from scrap were I work
Credit to Gizmo for his original
#89
ROCK ON !!!!!!!!!!!
![Coolcowboy](/forums/images/smilies/more/coolcowboy.gif)
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!
![Drink](/forums/images/smilies/drink.gif)
