X-dimension Volvo to Bravo swap
Hi, I am in the process of converting my 27 mag with Volvo 280's to Bravo Ones as the time has come.
By my research it seems that 16.5" is a good number for the X, but I wanted to make sure ...it seems as though that number will put the new drives quite close to where the old X was with the Volvos which kind of confuses me. I always read that Magnum put the Volvo's a bit deep on the boat and that is why they were a bit slow... is it possible mine were higher than normal? The boat only did 56mph so I think that was right in line with the power I have ( 320 chris crafts flv's) and other Volvo boats. Does anyone have a comparision measurement for 280 to Bravo propshaft -crankshaft hieght difference?
I have one chance to get this right and would value anyones opinions on the matter. The only thing I want to avoid is cutting my hatch, so I dont want to go too high. Going with stainless marine manfiolds and risers updgrading from the huge log manifolds on the motors now. Looking to gain some top end obviously but cruising efficiency and lower planing speeds are just as important to me.
Thanks!
Paul
27sport
Thanks!
Paul
27sport
Paul,
I can give you some measurements from my boat...it works really well.
E-mail me at [email protected]
Aaron
Aaron
Thanks all ! This is really helpful. How much does tank palcement affect this, I have 4 tanks : 2 50 gal in the seating area , and 2 35 gal in the berth but they are not used. Some boats have only the tanks in front I think. What affect would this potential balance change have, if any on the X?
Based on the feedback I am thinking 16.5 or 17 is probably best. I have always ran 3 bladed props , I dont have a lot of experience with 4 bladed props .
Paul
Paul
Paul
Paul
To me, even with the X at a conservative height wouldn't the C of G swing towards the stern considering the 2 50's of fuel (under the cockpit sole) and twin engines past the mid point?........I'm new to this and I often wondered how bow lift is affected by a higher or lower X?.....I guess you always have those 2-35's for some foward ballast if you need.
Paul
Paul
i can take measurements from cig92's magnum. he knocks on the door of 90mph with his warmed up 500's. he has volvo plates with bravo gimbles on his boat. trick setup for sure
