Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Any suggestions on building a gauge pod >
Old 01-01-2008, 09:15 PM
Crazy Energy
Velocity Vector's Avatar
Default Any suggestions on building a gauge pod
Velocity Vector is offline
Old 01-01-2008, 09:21 PM
northernoffshore's Avatar
PVC pipe cut in half and shaped, mold for glass.
northernoffshore is offline
Old 01-07-2008, 07:00 PM
Northernoffshore's Idea Is Probably The Best Way To Go... The Other Thing You Could If You Didnt Want A Bunch Of Little Humps Is Cut The Center Section Of The Hump And Lift To Fit The 3 Large Gauges And Glass It.
I Have A 260 And Wanted To Remove The Dash Hump Is It Finished Back There?
007joe is offline
Old 01-07-2008, 08:22 PM
Crazy Energy
Yes it is finished back there, at least on the 320
Old 01-07-2008, 08:39 PM
Charter Member #232
Audiofn's Avatar
You can also take some expanding foam. Pour it into a box and just shape the stuff tell you get what you want. Then you can just glass over the top of that. Works killer. Wish I had a picture of some of the speaker pods that I made.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-08-2008, 06:06 AM
Crazy Energy
Here is what I came up with, I used the green floral foam very easy to shape.
Old 01-08-2008, 08:00 AM
Charter Member #232
Audiofn's Avatar
There ya go!!! Make some tests with resin. That grean foam will react poorly to a LOT of resins. Just take a piece that you cut out and run a test with the resin that you choose.
Audiofn is offline
Old 01-08-2008, 08:01 AM
Charter Member #232
Audiofn's Avatar
Oh ya and once you make the fiberglass outside you can just pour accetone in there and the stuff will all ment out and you can have it all hallow
Audiofn is offline
Old 01-08-2008, 08:33 AM
NICE JOB!!!
007joe is offline
Old 01-08-2008, 08:58 AM
Neno the mind boggler
glassdave's Avatar
make sure you leave yourself enough room to access the back of the gauges to attach wires and get to the mounting hardware. also if that foam reacts to the resin you might try using an epoxy instead of poly or put on a barrier. PVA or even something as simple as just covering it with a layer of masking tape. good luck, look'in good so far
08 OPA High Points Champion
glassdave is offline
Quick Reply: Any suggestions on building a gauge pod
