Diary of a mad man part 2
#31
As i look thru my pics i realize the sequence of events are a bit jacked up. Phone swaps and gallery folders are killing me...lol. I am trying not to jump around with what im showing but the work i did and the ADHD in me is all over the place. When one part doesn't show up or fit im on to the next item i can tackle. Hence ,.....now the whole boat is blown apart...
Stormrider (01-30-2024)
#32
Started modification on windscreen and hatch
Uremoved the tie in on the hatch where canopies tappered back. Looked killer with canopies but not so much without
Getting closer
Getting closer
The following 8 users liked this post by tomcei:
105Fountain (01-31-2024), 12meter joe (02-02-2024), beckmwi (01-31-2024), bulletbob (01-31-2024), hogie roll (02-02-2024), Hoodoo 2.0 (02-05-2024), Stormrider (01-31-2024), WavetoWave (07-14-2024)
#34
So at this point I'm good with the over all lines of the boat. Blacking out the windscreen helped. I am working on some little nick knack pieces for the vent holes and still cleaning up the interior, we'll actually stripping and cleaning out the interior. I'll post pics of the stripped out dash and floor soon. I'm also still assembling powder coated hardware in the bilge. I went round and round with some used mtrs and took a bath on that deal. I've licked my wounds and Finally broke down and decided to go with some ultra tall Dart blocks and Heads. Building 632 NA to run on 89/90 pump gas.
Twin O/B Sonic (02-01-2024)
#35
Template over New flooring
After stripping i Coated with imron
Popped in a mechanical heads up ,
Rebuilt the shifter assmy. Ended up changing color to black
Bling for the vent.. had a local shop cnc this for me from a template i made
Rebuilding the seat bases for correct height and slight recline to work with the new seats
Had to mark cut and reweld the mounts.. i will powder coat black
Newly assembled with color change
Interior goodies.
Made some foot rests
Trimmed them out with flooring to match
Mocking up some grab handles for the front seats.. wanted something to hold on to while adjusti trim and tabs.. i will cover the handles with rubber and dress them up. White board is the backing for the new upholstery
beckmwi (02-01-2024)
#37
Thanks..story of my life.. spending more than I should.. more misc interior pics..
Finished my front seat grab handles
Trimmer out the switches
Going with a carbon Fiber dash
Seats are done..also covered the console to match
Twin O/B Sonic (02-02-2024)
#38
Side panels done
Went nuts with ideas playing with switch layout
Dash template
All holes drilled finally... measured a dozen times on each cut
Starting to come together
#39
Cleaned up a lottle..i made a trim molding out of aluminum and powder coated it black for the console base.. this will tue in with the seat bases.
Foot rests in place
The following 4 users liked this post by tomcei:
