Cup size for Tantrum >
Old 11-17-2009, 11:15 PM
Received 4,723 Likes on 1,350 Posts
Originally Posted by My Addiction
How is your hatch sagging, mine has a fiberglass base and then the pad has a half inch starboard base that is bolted to the fiberglass, no wood. Is yours not like this?
I thought there was wood in there, haven`t taken it apart thou.
Some of the screws at the bottom .. whetever they screw into.. i thought wood.. are stripped. When it goes up it`s all lopsided.
Side with lift goes up quite a bit before the other side follows. Any remedies?
ICDEDPPL is offline
Old 11-18-2009, 02:05 AM
Received 1,932 Likes on 971 Posts
Install a gas shock on the side that lags behind.
Griff is offline
Old 11-18-2009, 09:47 AM
Theres one there.. maybe its shot
ICDEDPPL is offline
Old 11-18-2009, 03:59 PM
Put the lift in the middle if only one lift.
laszlo01 is offline
Old 11-18-2009, 08:20 PM
I thought about doing that. can you post a pic of the shock mounted or describe how it is mounted and what size shock its is?
My Addiction is offline
Old 11-18-2009, 08:24 PM
Easier said than done with a single engine.
Old 11-18-2009, 11:32 PM
I can snap a picture for ya.. so you sayin yours does the same?
ICDEDPPL is offline
Old 11-19-2009, 03:44 PM
yea, the actuator is on the starb. side and when it goes up the port side is about 3 to 4 inches lower.
Old 11-23-2009, 05:43 PM
Heres the pic.
the shock is fine.. pretty strong actually, I had a hard time pushing it back down.
And yes theres no wood in there now that I took if off and saw underneath.
The lift bends the fiberglass base and overtime that strips the screws attached to the starboard. There is a piece of that starboard stuff thats broken.. I`ll have to figure out a way to fix that.
btw, Addiction were you the one that posted the pics of your interior? you had some things powdercoated? Am I remembering right?
I`m sending the rails and grab handles out.. would like other ideas, thanx
ICDEDPPL is offline
Old 11-23-2009, 07:39 PM
Why don't you install a pair of new actuators, one on each side. That's how Sonic does their single engine models.
509 SC is offline
