Leaking power steering fluid.....help
It also helps if you have a locked out distributor and control the timing with a programmable ignition box. Such as a digital msd 6. If you have any mechanical advance in the distributor it will aggrevate the problem. With a digital box you can also put a boost retard curve in with a map sensor and run more boost... more power!!
