2 questions for Pat >
2 questions for Pat
2 questions for Pat
Old 10-24-2015, 08:23 PM
Default 2 questions for Pat
1- what is the brand/part number for the rub rail? Not the stainless insert, the rigid vinyl piece the insert goes into.
2- who is the manufacturer of the front boltster seat frames? Drives side seat base is bent and want to contact them on getting a new one.
Appreciate the help!
Boat is an 09 if needed.
Pwraddr is offline
Old 10-24-2015, 08:34 PM
boatfreak's Avatar
Damn what have you been doing up there. I mean you're just a lake boater.
boatfreak is offline
Old 10-25-2015, 08:21 AM
ActiveThunder's Avatar
Taco Metal. V21-9613WHC20D
I have the seat bases custom made. It takes about 4 weeks. $1900 for side by side, powdercoated.
ActiveThunder is offline
Old 10-25-2015, 08:23 AM
BTW, bent?? I have to see this.
The only other person I have ever seen bend one was Gordo. But that went along with some broken ribs, I believe.
Old 10-25-2015, 08:56 AM
It is only the piece that your butt sits on, not the base of the unit. I'll post a pic later. I'm 190 pounds, unsure the previous owner. Figured since it is out and all apart I would replace, but don't want to buy a complete setup for that little part.
Thanks Pat for your help!
Pwraddr is offline
Old 10-25-2015, 09:14 AM
Ship the part to me. I have a set of stands being delivered in about a week so will give it to the owner to duplicate.
Old 10-25-2015, 11:04 AM
Let me get it apart, appreciate your help.....many thanks!
Pwraddr is offline
Old 10-25-2015, 06:15 PM
The problem was the tube was hollow with welded end caps. Now they are solid, drilled and tapped.
Old 10-25-2015, 08:03 PM
Relaxing's Avatar
190, Really.
Relaxing is offline
Old 10-26-2015, 02:50 PM
CIG3's Avatar
Gordo got off easy on that one. I ended up with a fractured orbital socket and 21 stitches around my eye (that was with a helmet). Thank god he is an EMT and got us to shore and to the emergency room.
For all that we can same a 25' will do 84mph with an 500HP. Not recommended....
CIG3 is offline
