Extreme Measures... Make Over Edition >
Old 02-06-2023, 06:28 PM
  #131
Rookie's Avatar
Received 1,249 Likes on 604 Posts
Originally Posted by TexomaPowerboater
Where did you get those stainless exhaust rings? I have not been able to source one with four holes, they all seem to have three and my original ones were four.
Teague has them relatively inexpensive. Make sure you order the seals also. I used the 5" I.D. The gaskets will seal down to a 3.5" pipe. I did not use the ones I cut out. Cheaper than buying used.
https://teaguecustommarine.com/catal...ing-ki/id/324/
Rookie is offline
Old 02-06-2023, 11:25 PM
  #132
Thanks!
HOLY CRAP, $40 for a single gasket! I've got 4 in exhaust and no big gap between rings so don't think those wider Teague ones will fit, but wish they did they are quite a bit less.
I've enjoyed the thread, lot of hard work in this beauty and such a wonderfull resource for others. Thank you for sharing. Really a work of art all that was put into it and new dash. Suprised some of the work that was required, but that is a great hull and cabin, it will be worth it. Really amazing some of the craftmanship on these boats. Its funny, watching bright people really put their entire life of knowledge into something they consider SACRED, time on the water.
TexomaPowerboater is offline
jbraun2828 (02-07-2023)
Old 02-07-2023, 07:44 AM
  #133
Received 1,389 Likes on 776 Posts
Thanks!
I've enjoyed the thread, lot of hard work in this beauty and such a wonderfull resource for others. Thank you for sharing. Really a work of art all that was put into it and new dash. Suprised some of the work that was required, but that is a great hull and cabin, it will be worth it. Really amazing some of the craftmanship on these boats. It's look again the SS ring is $40funny, watching bright people really put their entire life of knowledge into something they consider SACRED, time on the water.
Look again the SS ring is $40 the gasket is$15, so total $55 per hole. Kind of expensive I guess but they work well, I still use a layer of life seal (or 4200) just to make sure. Mine are so tight I had to use WD40 to slip the gaskets on and have tested them they seal very well.
Wildman_grafix is offline
Old 02-07-2023, 12:18 PM
  #134
Was looking at the stainless marine website. The ones Teague has won't fit. I have 4" exhaust tips and the rings are probably 4 1/4" or 4 1/2" ID. The old setup just had an O-ring to stop the water and would of rotted out the transom were it not for a 1 inch layer of balsa wood.
Old 02-09-2023, 07:45 AM
  #135
Rookie's Avatar
Thanks!
At $50 a hole for ring and gasket I thought was relatively inexpensive compared to the others mentioned. I had the same spacing issue on my Panther. I just cut ~1/2" flats on the 2 inner rings and butted them together.
Rookie is offline
Old 05-28-2023, 10:29 PM
  #136
Rookie's Avatar
Just a couple quick upgrades. The flooring has always been trashed since I picked up this project. And the Loncoin is extremely hot! I always have towels down. Not only because the unsightly stains on the floor, but also the nuclear reactor that is housed inside every plastic circle of the old flooring. I also mounted USB plugs for my Holley ECU's. Hopefully take it out tomorrow and get in gear idle sorted out, wants to stall out.
I will try to install the new digital dashes soon, but work gets in the way of my boat projects.
Rookie is offline
The following 6 users liked this post by Rookie:
87MirageIntruder (07-27-2023), bencini231 (05-30-2023), hblair (07-26-2023), rak rua (05-29-2023), SC288 (05-29-2023), TomZ (05-28-2023)
Old 07-25-2023, 03:05 PM
  #137
Rookie's Avatar
No real updates. Just been out enjoying the boat this summer and working out some issues with the EFI. One engine is down a little on power compared to the other, but the vitals are good and is a re-freshed engine. I'm looking at coils, RF interference and other stuff. Port (dynoed engine) is stout and the STBD lacks a few hundred RPM.
Rookie is offline
The following 7 users liked this post by Rookie:
87MirageIntruder (07-27-2023), bencini231 (07-25-2023), Griff (07-25-2023), hblair (07-26-2023), rak rua (07-25-2023), SC288 (07-25-2023), TomZ (07-25-2023)
Old 07-25-2023, 08:34 PM
  #138
Thanks for the ride Jason, the boat is awesome! An absolute beast in rough water!
SC288 is offline
Rookie (07-26-2023)
Old 07-26-2023, 08:27 AM
  #139
Rookie's Avatar
Any time and great seeing you and the family. I'd like to think it's the driver and not the boat... lol
Rookie is offline
SC288 (07-26-2023)
Old 07-26-2023, 09:11 AM
  #140
I forget what screens are those? Easy to see in daylight?
