Drain plugs
AKA NoMoBoatin
Drain plugs
Pat did you find out about the drain plug location and if it can be done for the step drains?I drilled the 2 holes in the step and all i got was foam and a little water coming out of the portside when i drilled it.I also need the answer to the question on the ticket for frank that we talked about.Would rather have the settee custion and table instead.call me soon with info please need to finish or fix step drains that are drilled.Thanks Rich
Re: Drain plugs
Dock, if you would like me to, I could trace a pattern of my drain plugs with dementions so you could know where exackly they go? Let me know if this would help you.
