Go Back  Offshoreonly.com > Owners Forum > Advantage
34' Offshore Drive Alignment >
Old 08-10-2011, 08:42 PM
Default 34' Offshore Drive Alignment
Anybody here have a 34' Offshore? What is the centerline of your drives? My transom centerline measures 36", should i run the drives toed in some?
Advantage 575 is offline
Old 09-20-2011, 02:59 PM
I don't know the CL of the drives on my 30 but I run them toe'd in about 3/8"
LHC30Victory is offline
Old 09-20-2011, 03:17 PM
Thanks, currently i have them in about an 1/8. boat seems to wonder a little. I think it's because the 34' seems to list to the port side. Is there any 34's on this site? If so do they list to the port side?
Old 09-20-2011, 08:54 PM
At slow speeds, all v's tend to wander a bit. At higher speeds, you may want to pay attention to the trim, it may be bow steering. That has been my experience with the 30 and a heavy open bow. I need to trim it up to keep it handling well. I suspect the steps have something to do with this also, but am not that much of an expert to tell for sure. Is all your weight balanced otherwise?
