Planing Issues....
Re: Planing Issues....
Why not try a 24 4 blade for outings with guests. Your overproped for your set up with that many people in the boat. I have a 26 AO with a 598 running a B1 with 1.36's and a Imco shortie spinning a 29 p5X and she pops right out of the hole. I was running a Bravo 1 32 4 blade that would pop right out of the hole as well. Try a smaller prop with guests in the boat and I bet your troubles go away.
born2burn. 5 blade works well? alot of money to spend to try a 5 blade!!!!! are you blown? i didn't know how to interpurt your last post.
OUrs is naturally aspirated.
I read on Speedwake you were trying out a 30p bravo 1. How's it work out? I have a 30 Bravo 1 thats been worked down to a 29p and less cupping, will sell cheap if you can use it. I'm still confused. Naturally-asperated to me means carbed. Are you running a blower?
NO BLOWER...........Yes naturally aspirated means carb.....one measly little carb. Havent tryed a 30 yet was going to try a 30 for just a cruzing prop.......or when I have a full boat load and full of fuel and use the 5 blade for the speed prop. Need a spare prop anyway.
Have you had it to 5800-6200 rpm or is that what the person you bought it from says the top rpm's are? If all you have had out of it is 5500 then by going down 2" of pitch yuu will plain quicker & gain about 300 rpm's on top.
Not thinned(labed), just some cupping taken out, pitched down to 29. $100 plus shipping if you want it. Boy, your 598 must put out dome low end power....
[email protected]
thanks
Todd
