Wiring harness diagram 96 NSX
I'm re-doing the dash on my NSX. Carbon fiber panels. Getting rid of the duplicate gauges. Anyone got a wiring diagram for single gauges? My question really is, what do I have to do with the wires running to the duplicate gauges on the passenger side? Can I just terminate them? That's tach, voltmeter, water temp and oil pressure.
Were doomed!
unless you realy need to clean up a rats nest or just want to get rid of the wiring all together...i would just terminate and tape them and forget about it. Most dual gaue setups run an extra set of wires to a dual sending unit.....so if you realy wanted to get rid of all the wiring you would need to rip a few wires out all the way back tot he engines....the tach,lights,ing,grounds are all just jumpered from the first set fo gauges....
-Wally
-Wally
Sounds good to me. I just didn't know for sure that it was double wiring or something special was done. As long as the daisy chain for ground and gauge lighting is complete I should be ok. Thanks for the response.
