Speed out of a Procharged 25 Outlaw ? >
Old 06-20-2017, 09:51 AM
  #31
Default Prcharged 250 outlaw
I am running a similar setup on my 250 SST. 502 with a 30P Bravo 1 at 7PSI boost but i have IMCO Exhaust and have to have perfect conditions to reach top RPMs by over-trimming the drive thus losing handling. just ordered a 28P. when things are perfect and running the 30P I squeak past 80mph but it is very inconsistent on even being able to reach 5200 RPMs. When I took it to Crocket he set it up correctly (First mechanic was clueless) He ran the boat and I had no speedo but the math said Mid 80's which is where it should run I have been told. I have since proved it on GPS. and again get a fuel pressure gauge and a boost gauge so you can eliminate and concern about belt slip and running too lean on fuel so you don't grenade your motor. I will repost after I run the 28P as of right now I am with Catsmeow
Blown Asset is offline
Old 06-30-2017, 10:27 PM
  #32
This thread was like 12 years old brah..... guys could be using walkers and canes by now
IGetWet is online now
Douglas811 (11-14-2021)
baja36ft
Baja
25
03-26-2012 10:42 PM
JasonSmith
Baja
7
09-07-2005 12:05 AM
mpally
Baja
13
08-10-2005 10:32 AM
yesrej
Baja
49
07-13-2005 07:13 AM
Rocko C
Prop Talk
5
07-01-2005 08:56 PM
Quick Reply: Speed out of a Procharged 25 Outlaw ?
