water in v-berth 1994 outlaw 24 Help!!!
Anybody knows how to stop the water from filling the nose of water under the last cushions ? No holes to drain there... the only place I think the water comes from are the pop up cleats. Do you guys have a hole in this triangular place to drain it ? What do you think is leaking?
Thanks for the help!
Check for ample caulking around cleats, bow light, and horn. It seems at times there is a "caulk shortage" at the factory that can lead to the symptoms that you describe.
Easy fix just pain in the azz.
Mark
Mark
There should be scupper drains for the nose cleats. Sometimes the drain hose for the scupper can come off and dump water into the nose bulkhead area.
The same happened on my Outlaw. The hose came off the drain fitting and it filled up the bow area with water. Take off the cover panel and take a look.
