Good Deal on Billet...
Charter Member #601
Re: Good Deal on Billet...
Dock,
these caps will fit drives with X, XZ, XR gears. The newer OM drives have the newer gears and will bolt right on with proper shiming for gear lash. If they are used on an older than OM standard Bravo and X gears, they will need special shims to make sure gear lash is correct.
They CAN'T be used on the old style thin floored gears. The tower is too short to accomadate the old style gears. Standard Bravo's that have not had the gear upgrade kits installed are included.
I hope this info helps.. I will be glad to explain further if need be!!
Dick
Dick
Charter Member #34
Originally Posted by Mr Gadgets
Dock,
Dick
Dick
Thank you VERY much for taking time to respond to this thread.
Everyone that knows you, knows that you are the drive guru and respects your opinion and ability to set up an outdrive the proper way.
Dock
