500efi"s time and rebuild
i'm looking at a 01 36' baja with 500efi's and was talking to a salesman that said you have to rebuild after 400 hours anyone out there can help me would be appreciated. thanks.
I don't think you HAVE TO do a rebuild, but definitely do a leakdown test and that will tell you more. Then you may only need to have the heads refreshed and then rock and roll.
do a leak down , if it passes change the valve springs or do a complete job and run it, Those motors should go 800hrs if taken care of. cost will vary , have someone with a good track record help.
Do a leakdown test if over 200 hrs.
Merc Racing recommends spring replacement and new head gaskets with a leak down test @ 250 hrs. If no other problems exist then around 500 hrs you should count on a rebuild. Rebuilding stuff that ain't broke is much easier than stuff that is.
The 250 hour thing is on non efi engines. They recomend 400 hours to do the valve cover pull and check the heads. They had problems with pre efi engines.
how much are you looking at to do everything at the 400 hours? i really need your help to determine if i'm buying this boat or not. please help asap.kdawg p.s boat had all leak down test and all replaced parts 20 hours ago. per owner
