leaking horn
Charter Member #34
I did on the 36 and always had horn problem so I solved it.
I very neatly taped over the horn with blue electric tape and sealed it back with silicone around the edge then put the bezel back on and you just see the blue tape through the slots. NO MORE WATER.
Then I mounted a $19.00 plastic dual trumpet air horn from Advance Auto inside the air intake for the engine and it works like a charm!
My horn was already bad and it was the second time I replaced it so I made a change. If your horn is still good you may just need to reseal it around the edges. It needs some silicone because the gasket alone is not enough.
Good luck.
Good luck.
Also check the cups below the bow cleats if you have the popup cleats. They crack and leak water too.
Had the same problem on my 1999 36 Outlaw. I started by caulking around the base of the horns on the exterior. I was getting water in the area in front of the bulkhead and it was to the point it was seeping into the v berth. I removed the bulkhead to drfain all the water. While it was removed I caulked the horns from the inside. There must have been a horn caulk shortage the day mine needed it as there was little to none on the inside. Now on the other hand on the other thru deck items in the area there was an over abundance.
That is the approach I would take if I was you. Get to know your boat better in the process!
Mark
Mark
Ginger or Mary Ann?
Don't know if your boat is cored there or not, but if it is, make sure the coring has been sealed with resin. Otherwise the coring will soak it up like a sponge. Water between the inner and outer skins ain't good. Just going on the fact that all the holes drilled thru any glass on my Baja were not sealed and the coring was wet.
Good luck.
Good luck.
Thanks for the advice. One reason I've been using a full mooring cover since 04, stop the leaks. Just one more small bug to iron out. By year 10 of ownership, I should have this thing perfect
![Lolhit](/forums/images/smilies/more/lolhit.gif)
