Baja 32 Caliber
the 32 is a nice boat and baja did a nice job but like formula they did the same think in the 80s and earl 90s plus others , if they used wood or balsa when they did there cut outs they didn't seal the holes like on mine the deck hatches and after years of running in 99 I had the balsa done over where needed in my deck the cut outs recut but this time they take out the balsa between the fiber glass fill it with fiberglass compound so its impossible for water to get back in between. my motor cover I got rid of the wood used balsa and a pro stock scoop. light weight and you can jump on it. and if baja put a full bulkhead in front of the motor and going in the cabin the 240 sport or 24ol would of been a lot more solid boat. glue down carpet is a no no too. in the bilge you need to pre seal the screw holes to. love my new saber it has 7 bulkheads only wood is one sheet in the transom so you can screw your wires and non through bolt pieces to it. and help noncrushing when mounting gimbals k planes. they do a nice job on there 28s 34s 41s. good luck with the 32 I use to run one on the cape he ran in the 60s with bravo 1s and 454 365hps
