boss 272 help
1 Post
But yes, call Bblades. He's great with the Baja's.
http://www.boatownersworld.com/Props...us2_4blade.htm
I haven't seen it- the only Hammer I've seen on the south end is an all white with a really simple, swoopy, yellow and black graphic. But then again, I see at least 2-3 different/new boats just about every weekend!
I boated Cocktail Cove from 1998 to 2004. I sold my all yellow, Boss graphic '01 Hammer to a guy that lived on Lanier. I didn't want to ruin it by bringing down here to Florida. Nothing against the couple I sold it to, nice folks, I just wish I had never sold that boat. Left them my folks number and told them if they ever wanted out of it.... Just hoping they baby it as much as I did. Keep a look-out for me.
Back on topic for Taube. I ran a 23P High Five last weekend. It performed same as my 23P Laser II (much different prop than your Bravo I Prop, I run a SB motor) in all but top end speed and rpm. I could turn 400 more rpm and lost 1.9 mph compared to my Laser II. I'm following your thread with curiosity as I'm reproping as well and stuff is not adding up. Some items I have learned, the hard way mind you, is pay very close attention to prop diameter and cupping along the pitch and rake lines. The 4-blade I'm dialing in now behaved completely different with just tip-cupping added (cup along the rake lines). Those with more knowledge correct me if I'm wrong, adding cup along the rake line adds more rake, cupping along the pitch lines adds more pitch. AND, most importantly of all...make sure the blades are all "trued." If they're off even 1 degree you'll think that prop is no good when it very well may be. Keep us/me posted on your progress and I'll do the same for you.
Kennyo, what prop are you running on your 272 ? I have 98 Boss with a 509 M3sc Procharger a XR with imco -2' shortie and running a stock 30 bravo prop. Not sure if this is the right prop for my set up.
Ok, I got a hold of a 22p 4blade bravo 1 this past weekend... I also fixed my fuel sender and found that I have had 3/4 to full tank of fuel with all this testing.. anyway the 22 brought my rpm's up to about 4800 and my speed was around 62.. that was with 2 people and 3/4 tank, cooler and gear.. I'm just under half tank now and will run this prop down to 1/4 tank to see speed and rpm.. my guess is it will be about 65 at 4900 to 5000 rpm.. then I will throw that stock 23 mirage plus on again.. I'm also gonna try the 23 4blade turbo prop again once the hub is replaced.. I ran 64 mph at 4800 rpm with that with 3 adults and probably just under half tank.. the weather has been low 90's and up to 70% humidity..
