head gaskets
the mechanic told me he is very familiar with putting m1 procharges on, so i hope everything goes well.
The other guys posting on here are spot-on. Find someone who has SUCCESSFULLY built a supercharged marine motor that has lived for more than a season, and go with them. Also, give some thought to upgrading the steering on that boat for the speeds you are likely to reach if it is done right. Full hydraulic steering would be best, but at lease add something like a Drew stabilizer to it. A broken helm cable at 80+ MPH would be disastrous.
Head gaskets do fail faster on supercharged applications VS N/A low compression applications as far as head shifting around but should still last 100's of hours unless your motor is detonating itself apart , improperly assembled or is overheated.
Your engine should have quality head gaskets with the proper finish on the block and heads surface, Cometics/MLS are nice but I have ran felpro marine gaskets with more boost than you run and they have been fine also. You should have head studs if you do not want as many chances of problems. Procharged motors blowing thru carbs OFTEN have tuning problems as far as lean or rich spots at some point, since it isn't possible to re-jet your carbs with different sets of jets at every 200 rpm interval and manifold setting's like a efi set-up allows so it is very important to run your motor on the water with a afr gauge on it, if you find a lean spot that can't be richened up without making the rest of the rpm bands pig rich that might be a spot that you just don't drive at. You have made several post mentioning your mechanic that cast doubt on his abilities, if this guy isn't good at supercharged motors/tuning AND EXPERINCED I can see alot of frustration and money wasted in your near future , Smitty
i blew a head gasket, the marina said, i did little to no damage to the heads. They are bolting down the head gasket better as well as puting a better one on it. I run 93 octane in it, it calls for 91 but i put 93 in it. the before me said he put octane boost in it, i am sure that didn't help the head gaskets out. the mechanic is going to tune it for me and put a msd box and a chip in it. the original owner never put the rev plate back on , that is maybe why it went so quickly, there was nothing ther to control the rpms.
GEt someone who knows this stuff or you will be out of the water a alot.....
Is this a marina mechanic? ALWAYS run 93 no matter what, revs have nothing to do with blowing a head gasket, detonation does, gotta get timing under control, what was base timing set at? WOT timing? better not be more then 28 total....
Your head gaskets are blowing because of the cylinder heads literally lifting and stretching the bolts. You need (as everyone has already said) a very good gasket, and higher strength head studs like ARP. But you need to look into why the heads are lifting. More than likely you are seeing detonation which is the gas charge exploding due to cylinder pressure prior to normal ignition spark. This causes a ton of heat and like someone mentioned before, will melt or burn a hole in a piston. Obviously you need a boost gauge, and as others have mentioned, an a/f gauge. But most importantly, the whole package needs to be "tuned" each engine and supercharger need a unique tune to work together. You will be rebuilding a blown motor in a season or 2, that would have lasted 4-5 seasons or more had it been properly tuned in the beginning.
Charter Member #1171
yep,,,,in the dash a/f...fuel pressure,,,and if it was mine,,,,knock guage
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I woukda add egt gauge to the mixture... that will tell.you the most.... in boats u can reach 1450 degrees but that's about it... sterling says their 1550 HP engines will run 1500 degrees all day....at least that's what I read... my buddy's formula is around 1400 when beating on it... need lots of fuel and a good intercooler
I would like to get on the lake before the end of the season. i have been on the lake 2 hours this season , and the boat hasn't seen a coat of wax or a cleaning yet.. Full tank of gas though
Please wish me luck with the findings
I just talked to the mechanic and i feel comfortable about his ability after talking to him, i mentioned everything to him all of you guys mentioned and he is well versed on it. He is putting apr studs on the head gaskets and looking for the appropriate type of head gaskets for my situation. He said there was alot of water in the engine and he hopes no more damage was done or started. So he suggested if it was him to tear apart the whole engine to make sure no other damage was done and to correct any damage that is present or to preventive mantaince to stop and thing that may of started. I am crossing my fingers and dotting the eyes on my check book as we speak. So i will be out of the water for 1 to 3 weeks depending if no damage or damage and waiting on the machine shop to correct anything if necceasry. I pray it is just going to be a good situation when he opens it up and it was just a safty check not a fixing situations, but a bare amount of damage was done to the heads so i hope it gets better. Plus he is going thru the super charger and tuning it up and putting a msd box on it, and correct the steering.
