Engine hatch switch
From your link, I found http://greatlakesskipper.com/product...at-switch.html
I'm confused though. It is titled "Carling Momentary On/Off Momentary On." I assume this is not the same as On-Off-On momentary..?
Thanks for the leads!
I found this.
http://www.searay-parts.com/Carling-...icalvld1-1.htm
I'm thinking its close enough to fit in the hole and make connections.
What switch do you need I have several extras? It's just the dual throw momentary right.
Sorry just looked don't have one of those.
"Carling Momentary On/Off Momentary On". I have never seen them titled like that. I typically see "Momentary On/Off/On".
What is your take on this? Am looking at it too hard?
I should have some extra ones. I will look tonight or tomorrow to see. If I do I will be glad to send you one. It should be the same switches they use for the trim tabs and drive trim. You are correct they are on/off/on.
No rush. I think I'm going to purchase a whole switch panel with switches and covers so that I can swap out white switches for black and have the spare switches too. I figured its cheaper in the long run to go that route instead of buying each individual black switch cover and to have a spare switch here and there.
Ginger or Mary Ann?
You want a Mom ON/OFF/Mom ON
