Fast 232 ??
Thanks for the input guys. I appreciate any and all info on boats that are already done and running.I realize this boat is short, but Im going to extend the trim tabs to extend the length of the boat, Hopefully that helps the handling.Does anyone know if the H2X bottom is the same or similar to the 232 bottom? I know the H2X is a sit down boat and kind of the BAJA "HOT ROD."
This makes the H2X very fast,but when some waves you like the 23 degree hull much more!!!
It goes than much better forward!
full Offshorers have 24 degree,so 232 is not to bad for waves!
And 252 or 275 have 24 degree also!
Michael
Michael
i ran a 540 cid with a 3.3 whipple injected super charger with the large inner cooler 800 h.p on the dyno extensin box teague xr drive with imco lower unit large cav plates on my boss 232 the boat run high 90.s
CT River Baja (04-26-2020), kreed (05-05-2020)
