Anyone have a fix for loose bolster?? (long w/story)
Received 3,281 Likes
Thanks again Doc. I'm going to see how it works. If it does not work out (which I pray it does) I think I'll go with Mike and Bajalion's suggestion of the floor plate.
Thanks you guys, I'll let eveyone know how it works out.
Tank
Tank
Thanks for the pic....thats not bad. If the liquid metal stuff doesn't work I'll prob do that. Thanks again.
Tank
Tank
Same problems with passenger bolster. I have tried a few different things, all fail eventually. Tank, let me know how this approach works. I too do not feel like ripping the entire interior out of the boat, but if I do I will fix them all permanently.
Good to hear the tales of running hard. What numbers are you seeing???? LAter.
Allen, where you been bro?? I'll let you know how it goes with the liquid metal stuff Mark sent me as soon as I get around to getting it in there. The boat is running extremely well. I don't know what the numbers are do to my speedo being off. I need to get a radar gun or gps out there and check the actual speed...Also I think I may be a little over propped. I'm only getting 5k out of the 28 4blade. Soooooo, I"m going to try to get ahold of a 26 4 blade....Orrrrrr I can lab the 28 I have. Either way I need to get 5500 out of it.
