outlaw back seat removal
I was wondering how difficult a job it is to remove the back seat from my 1994 24 outlaw. The alternator needs changing, and last time I almost had to stand on my head to get it out. Is taking the back seat out a viable option to get to the front of the engine or is too much trouble and not worth it? Thanks, Andy
It seems easy, but mine was pretty tight. I would try to get to the alt without removing the seat. If you do decide to pull it, you may not be able to get it to slide forward, mine was too tight. I had to pull it anyway, I used a wench and a long rope. Becareful, it is heavy. Look for 4-5 bolts/screws on either side and 5-7 screws along the front of the seat, inside, screwed into the floor.
Just did it last week to replace my carpet. It won't slide forward easily as the grab handles will catch. The seat is in 3 sections, remove the top half, then the middle & finally the base. I had problems swinging the base around as it hit the bolster, It will take a little patience. I went to Home Depot & bought a movers blanket, lay it over the motor & just lay on top of the motor to to access the alternator. Should be only 2 bolts to remove.
I would leave the rear seat in.
John
John
