Bolster repair, 29 outlaw
I have a friend with a 29 outlaw. the bolts holding the bolster to the cockpit sole has loosened and will not tighten back up. I have not seen it but it sounds as if these are just large screws and stripped out when a rather large fella was riding with him. If I remember correctly....someone on OSO had the same problem and came up with a fix. What did you do and how well did it work????
Thanks,
Thanks,
i had, well still have, this same problem and asked for opinions on the board. The best solution is to get access below the floor and attach the seat with a bolt and nut. So far, that is more involved than I am prepared to tackle.
I don't know what year his 29 is but I have a 2001 29 Outlaw. The bolsters in a 2001 are thru bolted with backing plates. Perhaps with older ones thru bolting may not have been used.
![Confused](/forums/images/smilies/confused.gif)
mine is a 1999 272 islander, they are stainless lag screws into a stringer at the forward end, the aft leg is thru bolted into the floor only, good attachment hardware but poor support structure.
WUUHAHAHAHAAH.....WUWUWUWHHHAHAHAAHAAHAH
Okay.........I'm just kidding.....a bunch of us have had this problem. Tank just bought some "togglers" from West Marine. He may have the part numbers. I ordered them, but cannot find the part number or the thread we had on it here in Baja land. SO far they have worked really well for me in my 24 Outlaw.
That is my suggestion. If these fail I will either figure a way to put in a backing plate....or just sink the boat
If anyone from Baja reads this thread....PLEASE fix this problem at the factory during installation. It is a common problem among Outlaw owners. Perhaps this has been addressed in hte newre boats, mine is a 98.
Thanks....good luck
![Wink](/forums/images/smilies/wink.gif)
Thanks....good luck
allan, are you talking about toggle bolts typically used for drywall applications, that have been "marinized" and sold thru west marine for upwards of 10 times the cost as found at home depot???
I thought about that but figured I would be chased off of the board for that idea!!! Let us know more about that.
I am not sure if my bolt goes thru a stringer or possibly plywood floor. I do know that there is wood beneath the fiberglass but I cant even get the seat completely out to investigate thoroughly.
Yup....I paid about 14,000 times what they are worth....but if they work (so far so good) then they are worth it. I looked around for these things before I ordered from West Marine, but could not find any. I even went to a fastener place that has an entire warehouse, they had nothing.
Anywho......they are not stainless. Under your floor by the bolsters is either open space or foam, depending on where you drill. You should have gas tank clearance, BUT DOUBLE CHECK!!
I would recomend them as opposed to ripping the floor out.
Good Luck
Good Luck
