Outlaw 29 with Twin 7.4 Mpi speed? >
Old 08-20-2003, 07:54 AM
if the twin is this slow, how will a single with 496HO do, mid or low 50s??
WRedmann is offline
Old 08-20-2003, 12:32 PM
dave-o
62 seems alittle slow to me, but some poeple are probably running that when you consider full load of fuel 160 gal (1280lbs), 5 adults (800-1000 lbs) , coolers and everything else (200lbs), about 100+degress airtemp, and lack of good bumpy water. My speeds stated are very reliable/duplicated. They also seem consistent with the mods that I have made, I est. my hp is about 375-385 (crankshaft) and about 350-360 at prop, compared to the 454 mags @385hp@prop which barely break 70mph, I think I am in the ball park...don't forget about prop styles and drive highth instl which will also greatly affect mph.
Old 08-20-2003, 01:27 PM
Sea Ya's Avatar
4500rpms + 25p = 72mph , Not when I do the math.
Sea Ya is offline
Old 08-20-2003, 02:23 PM
That's where the word "optimistic"
comes in
Anybody that has these "highly accurate"
speedo's knows what I'm talking about.
They are a real ego booster ( 'til you
check it against a gps)
jt
JaayTeee is offline
Old 08-20-2003, 03:22 PM
I have a 272, with the 310 hp. I get an intimidating 55 on the GPS!!! If I run that thru the speed calculator
(HP/weight)^.5 * constant, I get a constant of about 225
Using the same range of weight over dry weight, and the 29 with 2x310hp, gets you about 67 mph, using the single 425 hp gets about 60. Is it reasonable for this hull constant to be the same for a twin vs the lighter single configuration?
WRedmann is offline
Old 08-20-2003, 04:41 PM
Charter Member #34
Dock Holiday's Avatar
I have a friend that just bought a 1999, 29 Outlaw with 7.4's.
Finally got to see the both on Lake Norman last weekend. He is all smiles after 5 years with the 272 he cannot believe the difference in ride quality. The 272 does good, but Norman is a very rough lake on weekends and he is cruising much faster in the 29.
However we were running side by side Sunday and I found myself slowing up for him. When we stopped he ask how fast I was running and my GPS speedo was between 62 & 63 MPH. He had four people in the boat, and I to not know how much fuel or what props are on the boat.
Just wanted to share this information.
Dock Holiday is offline
Old 11-22-2016, 10:50 AM
Originally Posted by Luv-N-It
I'm going to guess here, but there are plenty of people hear that know this more than me, but here it goes...
IMO I think lower 60's. I think the solid 65 mph all day is a push. I think you may see solid 65 all day with labbed props, but I'm guessing.
See how my guess comes out to the other "professional" opinions
how about a 2003 outlaw 496 375hp twins top speed????????
Gunn 68 is offline
Old 11-22-2016, 11:12 AM
F-2 Speedy's Avatar
Received 3,213 Likes on 1,433 Posts
This is a thirteen year old thread, but Im sure you'll get some opinions..............if your referring to a 29 OL ?? Im guessing mid to high 60's low 70's on its best day
F-2 Speedy is offline
Old 11-22-2016, 11:44 AM
thanks the marina told me 71 - 72 mph just though i would ask thought the speed he gave was a litttle fast thanks again
Gunn 68 is offline
Old 11-22-2016, 02:56 PM
Received 1,932 Likes on 971 Posts
That should be about right.
Griff is offline
adsman252
Baja
11
02-27-2008 09:59 AM
chevalcabre
Baja
14
09-06-2006 10:07 AM
JO - PANTERABOATS
Pantera
7
11-22-2002 12:43 PM
JO - PANTERABOATS
Pantera
4
10-18-2002 03:59 PM
26sonic
Sonic
3
10-07-2002 06:39 AM
Quick Reply: Outlaw 29 with Twin 7.4 Mpi speed?
