24p Or 25p On 25 Outlaw ?????????
Miami is right you need probably a mirage plus 23'', but mabye only a 21'' you want to spin it around 5,000 for the best perf. , there is not a 24 mirage , they are odd pitch , there is a 4 blade bravo one available in a 24 but is probably a little too much too a 22'' bravo would probably be the 4 blade for the boat. the 3 blade is almost always faster though
JEFF, Thats what I have now also and just had it lab finished by Daren @ Houston prop. I want to get a spare prop and wanted to try something different to try to get more top speed...
Stay with a 3 blade,I tried a 22 bravo on mine and it was awful,too much stern lift.I run a 22 turbo vector and spin it about 5050 on the tach,67 mph gps speedo reads 72.
Have you had any issues with the outdrive or engine other than your water rails busting? I am trying to get an idea of how many more hours I can get before stuff starts to fail. I assume you are changing your fluids regularly as I do. Mines an 02 with 100 hrs. Thanks for the info!
