Warning to those with Instatrim tabs
Charter Member #300
Hi all,
Some of you know latet Baja project swapping my Instatrim tabs for a real set of performance tabs. I bought a set of 24" tabs from a 35' fountain, sandblaseted (ground the Fountain logo off!), painted black. Look brand new. I'm also swapping all my indicators out for mechanicals including the drives. I'm a masochist, what can I say, but they are coming out great.
Anyway, I pulled my starboard trim tabs off and noticed soft wood. Water had leaking into it at the trim cylinder and where the tabs are screwed in. Long story short I too a dremel and cut out a small section from the inside and scooped the mush out.
I using a product from www.rotdoctor.com to fix. Drilling holes to inject the CPES and then using the filler to patch the scopped out areas.
I am very glad I caught this before it could spread and become a real disaster. Once water is in there, it does not come out on it's own.
Just a word of advice, I would periodcally take the screws out and shoot some sealer in there from time to time, epecially older boats. I sure some of you might have this going on right now. The new tab plates I gooped the hell out of with marine sealant as well as all the bolt holes.
B.O.A.T. - Bust Out Another Thousand.
martiniboat
11-10-2004 01:05 PM
martiniboat
11-03-2004 05:33 PM
