Banana Boat 24 set up
#131
Great documemtation and post.
I too have gone through the process of restoring a loved one!
You will love the ITS, I have one as well.
Its an expensive part but worth it.
I can turn my 20FT tunnell hull on a nickel with two fingers
Thanks again for documenting your work for us.
Uncle Dave
Uncle Dave
![Smilie](/forums/images/smilies/smile.gif)
Yes, I have high expectations of the ITS.
What boat do you have it on?
#132
I also have one on my "big " boat a Lavey 2750.
I have one a Laveycraft Sebring 20.8ft tunnel hull
Its got a 500HP 406 in it. Without the ITS landings from getting air were a lot more dramatic- now it flies and lands straight as an arrow.
I use the red boat for lakes and Rivers and the Blue one for the Ocean.
The ITS on the 2750 can muscle around that skeg around pretty easy as well considering Im throwing 700HP at it along with a considerable amount of weight because of all the goodies Im hauling around (radar/2 dvd's, ac/heat, monster stereo etc.)
UD
#133
Thanks! ![Smilie](/forums/images/smilies/smile.gif)
Thanks for your input on airintakes.
Yes, the air is up for discussions right now.
I showed the boat to a friend today and he said the same thing. It is probably going to be a lot of warm air for the engine if I dont open up for more air.
Before I take the decission to open up for more air I have asked "tomas_wallin" to do a calculation of the engine´s need for air versus the intakes the boat already has.
As you aleady know, I love the looks of the 24 race boat.
If its going to be scoops I will have a look at those scoop.
Right now I dont know if scrapping the sunpad is ok with my better half. Ha ha ha
Do you by chance have any pics laying around of the24 race boat and its scoops?
There is even a photo that shows the hatch lifted and you can see the holes underneath to let the air in. The small black clam shells on the side of the hatch face forward and the rectangular vents on the side of the hull just ahead of the banana decal.
The big scoops on the hatch face backward. Carl Kiekhaefer told me that even facing backward, they still allow a lot of air to circulate to the engines.
#134
Joe....boat looks great..... keep us posted with the latest photos.
#135
Actually now that I think of It I have 2 ITS's,
UD
UD
Where they rigged without the ITS before?
If so, what was the difference?
#136
There are quite a few photos on the banana boat co website www.bananaboatco.com under the racing section.
I see what you mean.
Hmm, need to think about this some more...
I might come back with some questions for you later on.
![Wink](/forums/images/smilies/wink.gif)
#137
Thanks.
The "big boat" always had the ITS so I have no point of comparison (and never really thought about it till after the post) to be honest I dont really push the bigger boat like I did the small one for fear Ill hook it, its only 1 season old and I desire to NOT to tear it up and mostly run point to point in the ocean using sweeping turns. I pushed it once once on a lake and it handled beautifully.
I planned on selling the little boat when I finished the big one, I was worried someone would get killed and come back at me so I put the steering on, new interior, new dash....you know how it goes.
The little boat was a regular bravo 1 no steering from 91-2008. I wore out three gimbals during this time and new I needed steering and budgeted 5K for an external system.
One downside of molded in swim steps was no room to mount external rams- hence the addition of the brutally expensive ITS.
Before the ITS The boats turning response would slow down past about 75 and at about 80 would basically only go straight until Id let off and trim down. Oh the wheel would turn- the boat wouldn't.
It turns now! like an F1 boat. I can run the bends at Parker wide open (about 90) with one hand on the wheel and make the boat do anything I want. Its an awesome component and it should be for what it costs.
I have to say I've only had a few tuning runs on the small boat but I believe the sportmaster lower cost me at least 2-3MPH at this stage. I dont know if its because my trim gauge is reading differently and Im not flying it as hard, or that I need to play with props to find my new sweet spot.
I didnt lose any stability so far.
Thanks again for the great work, and please keep em coming that Bananna is looking really great and you should justifiably be quite proud.
I want a ride!
UD
#138
Thanks.
I want a ride!
UD
I want a ride!
UD
Did you mount the ITS in the same position as the old Bravo transom?
I will be somewhere about 3" inch below the kiel with the prop shaft.
How about yours? Especially interested in the bigger boat with the V-hull.
Book a flight to Sweden late summer 2010 and Ill try to have her ready for a test run.
Edit: Sweet looking engine!!!!
#139
I make it to the Netherlands every september, maybe I can shoot over there.
Ive been trying to find my post where I talked about my x dimension measurements.
Im remembering something like 4 inches below center but my memory fails me every now and then.
its high enough to where when getting on plane I blow the prop out but all I need to do is feather it back and I hook and go.
Yeah testing..... I think Ill pay bob Teague to show up with his truck full of props. sounds like a lot worse ways to spend a day huh?
UD
UD
#140
hey looks good if you go to the baja section look at pics of my boat theres 3 or 4 pics with a scoop that mrv8outboard jeb and I MADE we made it out of balsa and a pro stock scoop and Iam making a new one for the blower motor thats going in the saber 28 if it ever gets here. also theres more pics on second thread by me maybe 4 more. you could jump on that hatch and it weights like 30ibs .I think 3'' prop shaft will be fine with the notched transom height . I am doing the same with the konrad ace drive. art
