borderline824 Thornton Cutchin
Add state it there in black and white, for Bravo. I agree. Sue the Ferktard!
seems kind of funny that he is looking for stainless marine dry risers after he sold me a set look at post #6 http://www.offshoreonly.com/forums/s...ne-wanted.html
Wrong again, you were given all the measurements over the telephone BEFORE you purchased them so that you could check your transom locations.. You contacted me again a few days later and said you wanted them. Your not telling the entire story, you were not scammed the details were provided to you as to what these were. I even gave you Jerry at Stainless Marine's contact info so you could obtain the layout and sketch for measuring your transom outlet height. Its funny you leave all of that part out of the story. I have made offers/suggestions on what to do. You have never responded on them. So instead of dealing directly with me you choose to complain about your dealings with me, giving one sided information that leads to no benefit or solution. Just wanted to set the record straight on that. You made a mistake by purchasing them, but you were given all info on the tubes to check your locations plus ample time to do so before you purchased.
Crazy Energy
1 Post
Stainless Marine Risers
Long risers through transom, brand new for bravo, make an offer..
You really should give his money back. Relist them for what they really are and move on with your life. If I sold you a Ford and when it arrived it was really a Toyota even though I told you it was a Ford and sent you measurements, would you except it?
![Evil](/forums/images/smilies/evilB.gif)
He has it in writing that it was for Bravos.
I had the samething happen to me once. I bought a motorcycle project, in the classified it said it was a 5 years newer then it actually was. After I bought it and went to buy parts for it I found out they wouldn't fit because the bike was older. I called the guy and told him he falsely represented the bike and he said it was my problem and hung up on me. I took the classified ad into small claims court with me and walked out with the money owed, less than 30 minutes later. Guy claimed that it was a misprint and judge said it didn't matter because he did not address the issue when I was buying.
He has it documented that they are for Bravos no matter what measurements you gave him. You never told him in the phone call that they were NOT for Bravos. This whole time you represented them as Bravos and did not correct the issue. It is your fault for either not knowing what you were selling or trying to pull one over on someone.
This is a clear cut easy win in small claims court.
