wear life jackets
Old 10-20-2008, 08:32 AM
Originally Posted by Lee
Life jackets are only effective if worn properly.
That Pix is pretty funny...
LOL...
Can't stop laughin'...
Divenstar
divenstar is offline
Old 10-20-2008, 08:47 AM
Originally Posted by boatme
The more i look at this the more i want to ask WHAT THE HECK ??
Lifeline is a type of life jacket not a line hooked to the boat
A tether is a string hooked to a kill switch
Apparently you are not educated in this terminology and i did not realise this at first reading your post
Consider yourself schooled
Kinda scary isn't it? It appears he owns a 31 and 38 foot go fast boat as well....
UP_ROKTOY is offline
Old 10-20-2008, 09:28 AM
boatme's Avatar
Yea i was thinking the same thing
boatme is offline
Old 10-20-2008, 09:36 AM
a teather should be worn as well
It is a small line (pretty much a string) not a rope! It is attached to a kill switch and to your life jacket or belt and if you go out of the boat it will shut the boat off! It is not strong enough to hold you in the boat
You should always wear a teather with your life jacket when on plane
Dardevil, If you dont have one on your boat you need to put one on
Scandelous, Obviously you dont understand the use of a teather, and possably dont have one on your boat ,but you need one. and should have one attached to your body in any "fast boating"
YES, i got one actually 2. Just did not know what they where called ,when mensioned above . LOL
I always ware mine since i stuffed my other boat.
Thanks though.
DareDevil is offline
Old 10-20-2008, 09:39 AM
boatme's Avatar
here to help if i can
boatme is offline
IS my check in the mail yet ?????? LOL
Old 10-20-2008, 10:19 AM
Charter Mod
BLee's Avatar
Here are some pics for reference in case someone reading doesn't follow.
BLee is offline
Old 10-20-2008, 12:02 PM
I think in reading this one could confuse "tethered" to the boat as being tied down to the boat in some way
I have never heard the expression "tethered" but am fairly new to performance boating
I've always used or heard kill switch or lanyard. it seems foolish not to wear it while underway though. since all these tragedy's it seems foolish not wear a vest also.
007joe is offline
Old 10-20-2008, 12:12 PM
Downtown42's Avatar
Originally Posted by 007joe
...I've always used or heard kill switch or lanyard. it seems foolish not to wear it while underway though...... since all these tragedy's it seems foolish not wear a vest also.
Here is the other choice
sonar scan at depth
Downtown42 is offline
Old 10-20-2008, 12:20 PM
sonar scan at depth
That is an eerie and grewsome sight....certainly ey opening.
My thoughts as posted on another website discussing jackets.
1. On plane, jackets on.
2. Idle speeds, jackets on weak swimmers and children.
3. 50+ you should strongly consider a lifeline.
4. 60+ you should more strongly consider a lifeline.
5. 70+ you should even more strongly consider a lifeline.
6. 80+ you should own a lifeline.
7. 90+ you should start to consider a helmet and a lifeline.
8. 100+ you should consider seeing a shrink
This is a sickness we all enjoy, its has its dangers, even with all the safety equipment in the world something can/will happen eventually. Take every reasonable pre-caution to make sure you and those around you are safe.
Edit* re-read first post.
Lanyard on before I start the boat. (when I have a dockhand with me, otherwise of course its on as soon as I get away from the dock and put the boat in gear)
Quick Reply: wear life jackets
