4 Blade Bravo 1 on a Checkmate?
Registered User
Anyone used a Bravo 1 prop on a 251 Convincor? I have a Hydromotive QIV on there now that runs great but it seems a little bow heavy at higher speeds. It takes a lot of trim, past the drive limit switch, to achieve decent speeds on flat water. I read the Hydromotive is good for boats have natural bow lift like the old Convincors, but maybe it's the all junk on board for over night trips + the AC unit mounted mid ship.
Rob
Stock bravo 1's have been the best all around prop I have seen for a Convincor. I would try on your boat the 24p bravo A labbed one will blow out and rev during crusing speeds and is only good for top end, and is useless everywhere else. Checkmates have no problem carring the bow so a bow lifting prop is no good.
my mate has a problem carring the bow. it rides very wet. i put a 23 mar plus on it and it road ok, but blew the prop out, labed and un labbed.
my 4 blades run much better, but i think with the rake right and labbed my 24 should be right where i need to be. we'll see wn brett finishes up the one i sent him yesterday![Coolcowboy](/forums/images/smilies/more/coolcowboy.gif)
Understand what you are saying but you also state that if you trim it. It will come up and thats a Checkmate. Theirs no need for a bow lifting prop if your trim will lift the boat. Thats what trim is for.
Let us know the true stats of the prop. I recomended NO 3 blades for any Deep V Checkmate
Obviously you have never been in a ZT hull. As stated here they ride very wet with alot of hull in the water. The recipe that BBlades has been using for Noyzee's boat and my old boat has to do a semi agresive lab and then add more cup back in, works great! With that being said Convincors and ZT are a totally different animals, for my experience Convincors traditional have no problem keeping the bow high!
sweet. was your 496 a mag or ho?
Purple, even trimmed way up, past the 1/2 way mark on the trim gauge it still rides very wet. i think brett was on the right path with the 26p but my boat just didnt have the power to turn it. i think if he does that to the 24 i sent him, i will be in good shape.
Magic, your right on. i can trim my boat up till i have a roost going, the boat goes no faster or slower after a point, and the r's dont change. the 26 bblades did for me seemed to work the best so far for carring the boat (still a little to wet) but with the lower HP mag i couldnt spin the prop past the 4400-4600 range. like i said, i tested the 24 b1 on my boat tuesday and it seemed to be pretty good but would only run about 4600-4700 rpm trimmed way up, so im guessing if brett labs it up nice, and throws what he needs to for the bow lift, im thinking i will be in good shape!!
i 2nd day aird him the prop, so he should have it today
ive ran 28 and 30 b1's 1.5 bravo, 88 251 convioncor, 509 blower, about 700hp... always seem to slip about 2800-3000 until you get the speed up, once at cruising speed about 45mph 3000rpm it hooks... i get alot of bow lift, he i am cruising at 70.
got it running at the end of last year, i had it 84gps about 5400rpm, that was for a couple seconds, i havnt pushed the sticks all the way yet!! im waiting for an xr upper, 700hp is estimated
Hornet,
