2002 Checkmate 270 BR
The checkmate factory could send you a brand new seat cover to match the boat for not much money. They are very reasonable and give them the hull ID number, they keep the full build sheets and can replicate it easily.
The engine can always be sold and swapped out easily down the road as well, if it is clean and what you want, go for it. You would want a 4 blade prop which the Hydromotive QIV is. Hard to say pitch wise, depends if they put the 1.5 or 1.65 ratio drive behind that motor. Best would be to run what prop is on there WOT, and tell us the pitch and WOT rpm you hit. Need a baseline to go off of really.
Check out checkmate-boats.com that is the checkmate owners forum. Lots of great people and info over there.
All I know at this point is its a 4 blade 19P, maybe try a 21, gears are 1.65. I will take it out this weekend and get a feel for it. I contacted Checkmate yesterday on the decal seat issues and looks like a good winter project. I can send the middle section in or send in the entire skin. see how it goes.
Boat has been on the market a couple weeks and only interest is Brokers and the typical Craiglist scams that is sending a guy over since the buyer is overseas.
Asking 26,500. Boat ran great,, Cruising speed was 40-45,, never did try WOT. Lake was busy on labor day weekend and we had out grandaughter with us.... I did not have any much trouble with porpoising just slight tab and was good to go..4 days over labor day is the only time I had it out..
