Motor mounts
#51
Charter Member #601
Convincer,
That boat looks GREAT!!! It does remind me of all that I did to mine years ago. Offshore mounts, etc..
Depending on your x demension .. The 25 Mirage worked best for me. But with higer x.. a four blade is recommend. I would try a 24 Bravo and then see if you can find a labbed 24.. that would raise the rpm about 300rpm they say. Also look at the hook in the bottom of that 25'. The molds did put a bit of hook in.. dont take too much out, or you will run into problems.. Let me know if you want more info.. on the bottom blue printing.. I will share my experience..
Dick
Just plain Awesome.. now about 700hp and you will be Mr. Big in your area!!
Dick
