The Last Stingers & Scorpions...
#34
hello i have a 26 stinger 1989 with twins 5.7 liter and alpha drives and i might need some information on performance to get a few miles per hour/i was getting 55 mph at 4700 rpm with a 21p prop and the guy that did my engines told me that since i put hydralic roller cam and i did a little bit of head work ,that i could easily run 5600 rpm and the engines will spin that with no problem but i will have to step down to a 19p prop.
please someone help me decide.
#35
i have more pictures of cabin and new engines coming to u guys
this motors are only turning 4500 rpm with a 21p prop.
t
my mechanic told me that this motors could easily turn 5500 rpm cause the are roller cams so i would have to step down to a 19p prop
what do you guys think?
t
#36
't have any digital pics,was a few years back
#37
Hey that would be great.I think it was red and black.Do you remember the HP it had?Eddito without knowing what's actually in your engines,specs etc it's hard to judge where you should be running them.Were they ever Dynoed?If they are the standard issue Merc motors with roller cams i would suggest 5000 rpm limit.If you are at 4500 now 19's should get about 5200 which is acceptable.
#38
hey guys, The last yr was 38 ft with a extra 3 ft build in swim platform making if a tad over 41 ft and 9 ft wide. see my picture on jokerswild posting. great boat. mine was a e p edition and was red white black. updated now. They also used a form coring system and a vacum bagging settup according to cc racing history site. I have all the info and and mine weights 10287 pounds full with 210 gallons of gas, light considering the size and beam..
