Oil Pressure Problem >
Old 06-12-2006, 03:24 PM
Default Oil Pressure Problem
I am having problem with my oil pressure dropping. I lost a motor about 3 months ago. I rebuilt the motor and put it back in the boat. I ran it for about a month and when i would power down from about a 15 min. run. My oil pressure would drop to about 10 lbs. I could crank the motor back and the pressure would still be low. If i powered back up the pressure would return to 50lbs. I changed the oil filter and that seamed to fix the problem. I figured that i might still have some trash in the oil cooler that i couldnt get out. This weekend the same thing happened. I changed the filter but it is still low pressure when i am idling. Can anyone give me some insight on my problem......Thanks
JeffC is offline
Old 06-12-2006, 04:10 PM
Mod Squad Enforcer
Cash Bar's Avatar
Default Re: Oil Pressure Problem
3...........2...............1.................Oh, LuckyStrike.............
Sounds familiar,I'm sure Steve will be along to explain.
www.gregsellswaterfront.com
Cash Bar is offline
Old 06-12-2006, 04:35 PM
GLH
GLH's Avatar
Jeff I would put this in General Discussion You will get the answer to your problem or real close to it!
GLH is offline
Old 06-13-2006, 09:46 AM
CIG3's Avatar
Sounds like a cooler problem. What is your oil temp? What is your water pressure?
CIG3 is offline
yves
Nor-Tech
6
07-02-2007 01:24 PM
sonic7175
2
08-08-2004 08:56 PM
kennyo
7
05-07-2004 04:45 PM
olysan
8
02-24-2003 07:00 PM
duster340
9
07-19-2002 06:23 PM
Quick Reply: Oil Pressure Problem
