TG fuel level senders - question
OSO Moderator
Has anyone replaced the fuel level senders in their TG?
Mine are not accurate and are not consistent side to side, was thinking of replacing them with the Livorsi style. Took a quick look at the sender location and it looks like a pain in the azz.
Is it?
Any tips / tricks??
Thanks in advance.
Is it?
Any tips / tricks??
Thanks in advance.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Received 3,219 Likes
My fuel guages are all off too (and the guages themselves are brand new). Isn't the sender units just little floats in the fuel cells? You can get to them through the access panel in the engine room? I need to get around to doing mine too
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Is it?
Any tips / tricks??
Thanks in advance.
Is it?
Any tips / tricks??
Thanks in advance.
![EEK!](/forums/images/smilies/eek.gif)
Originally Posted by seahawk
I did mine. Its not hard at all just use a short screw driver under the hatch in the engine compartment. Take the old one out throw it away put new one in no problem. Be careful not to make any sparks![EEK!](/forums/images/smilies/eek.gif)
Last time I changed mine I just removed the old ones and measured from bottom of the tank to the top of the tank and sent measurements to Livorsi .They sent new ones pre-cut to size and calibrated.There's also screws for any further adjustments.
![Cool](/forums/images/smilies/cool.gif)
I just helped a buddy of mine install the new ones (no moving parts) from Livorsi in his Top Gun. Pretty straightforward installation with minimal hassle
OSO Moderator
My install "looks" (from a quick glance) like there is all kinds of hoses/plumbing in the way.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
(aka) Pure Adrenaline
Originally Posted by barron
Last time I changed mine I just removed the old ones and measured from bottom of the tank to the top of the tank and sent measurements to Livorsi .They sent new ones pre-cut to size and calibrated.There's also screws for any further adjustments. ![Cool](/forums/images/smilies/cool.gif)
Same way I did the ones in my Mistress when I had it. It's the only way to go.
