99 Top Gun Water & Waste holding tanks.
FIERCE ALLEGIANCE
Here's the deal... 99 top gun.
I went to fill my water holding tank today with a hose so I could get it all cleaned out and winterized... I was impressed with how much it was holding. Looked into the bilge and the bilge was the only thing filling up with water. So I voided that idea and proceeded to poured some pink antifreeze into my head & flushed it and that too ended up in my bilge.
What am I up against? Water and waste tanks leaking? The bildge was filling up as fast as a hose could pump it...so it's almost like there is a hose off?
FIERCE ALLEGIANCE
Can you get them out and back in without destroying anything? Their both under the cooler in the cabin?
FIERCE ALLEGIANCE
Can someone either post pics or explain exactly where both the water & the head holding tanks are on a 99 top gun please? I need to replace them both. Also, any suggestion on getting them out or putting new ones in would be much appreciated. Thx!
Take out the tray in the head and you will see the head holding tank. It is put in place before the head is put in so you can cut it apart and take it out in pieces. but then you will need to see have one made that will fit. the OEM one will not go in or come out that same hole.
Or you can cut the side out of the head and take it out. Can't help you on the fresh water one, never replaced it.
While you have it out might as well rebuild the pump and put in a new macerator and hoses. The OEM company is still in business name is now RDS or something like that, if you search on here you will find it. I replaced on a few years ago and it's not a fun job
Yep..
FIERCE ALLEGIANCE
You had to saw this tank into pieces to get it out? Then size something that will fit back into the same hole? Wouldn't it make sence to cut an access hatch in the side (put in an inspection hatch) Has anyone done this? Any pics of what it looks like.
Also, still need to know where the fresh water holding tank is.
