How to put a Notch in a Flat Deck
#122
Thanks Scippy , hope you are right , but you never stop learning .
I hope to start the Magnum this winter . I want to enjoy the flat deck this summer .
RG.
RG.
#123
Rick, you should be good in that range. I had gotten the impression of more power from one of the posts. What is the peak rpm range on those mills? If your peak power is around 5500, you'll likely want to end up with 27 or 28's. I haven't opened mine up yet, (and may never be able to hold it all they way open...) but I can tell from the engine telemetry and my prediction calcs that going 92 required about 830 hp per side. Your hull is heavier, but I'm lugging around blowers and intercoolers, extra fuel, extension boxes, drivelines, remote tailstocks, etc, so weight prob ends up close.
My calcs show that with the 25's you will likely need to spin 5700 rpm, and 625 hp at crank to reach 80. If you get 27's I think you could get to 86 mph@ 5700, 725 hp. If you can't spin that high, 28's, maybe 29's.
they are still heafty mills for being N/A and @ 725hp I'm thinking Rick is being a tad conservative... all in all I'm looking forward to some fine fast boating this summer!!!
#125
Well we started to do the final rerigg . Got one motor in place . Just need to aglin shim and bolt her into place . Here is a picture from yesterday .
RG.[ATTACH=CONFIG]521198[/ATTACH]
#127
Very Nice Rick, keep the pics coming
