One of the five becomes a Six >
Old 07-31-2015, 09:40 AM
  #191
Zero Patience's Avatar
Originally Posted by Rick G
Great work ZP . I have one question being the over builder I tend to be , I would have added material to inside of the hull to compensate for the material removed from the exterior . Are you planning to do that ? Or is there enough material it is not a concern.
Rick G.
I never got past any glass, the notch the pickup goes thru is 3 5/8" thick. I estimate the hull to be 1 1/4 inches thick where the slots are. This from measuring at the drain plugs. These old girls are heavy duty. I know on a Beak I would have ground thru. I am waiting on the gel coat to cure now. Then we will bolt it on, and install the drives again. They will probably need 1.5 spacers, but we will try several.
Zero Patience is offline
Old 07-31-2015, 01:57 PM
  #192
I kind of figured that . Cool.
RG.
Rick G is offline
Old 08-02-2015, 07:06 PM
  #193
Pickups complete, drives back on, plumbing done
Old 08-03-2015, 08:40 AM
  #194
Looks great ZP . I have a concern on mine and I would think given those monster pickups you have the same situation . How are you managing water pressure . Does the system have a bypass of some sort you can manipulate or is it just done by changing the height of the adjustable pickup. My pickups are fixed and I am not a fan of the grind to tune method .
RG.
Rick G is offline
Old 08-03-2015, 12:38 PM
  #195
On my boat it was grind and tune, on this one the pickups are adjustable up and down, so we will control it that way. The engine comes back from Chief Wednesday, so we will install it this weekend, it needed a new oil pan, the PS cooler dripped salt water on it and made it ugly.
Old 08-03-2015, 02:13 PM
  #196
just read this entire thread..
what a read.. glad i read it. you did some amazing work on this boat. i love it
SKammeraad is offline
Old 08-03-2015, 03:04 PM
  #197
Can't wait to hear the numbers . Are you going to start with spacers or run as is and then add to tune ?
RG.
Rick G is offline
Old 08-04-2015, 08:43 AM
  #198
cougarman's Avatar
Originally Posted by Zero Patience
Then the slots were cut, and the pickup trimmed, cut, modified, to create the smallest amount of drag. A little more test fittings, and then gel coat the slots and polish.
Awesome work as always, Here are the pick-ups I built for my boat.
Same concept with keeping pick-ups above running surface, and allowing
water to flow up and it. Had 90 hours in building them....
Also notice the adjustment arm on them, I can adjust the internal pipe up
or down from inside the boat until I have desired water pressure.. then lock in place.
Jon
Attached Thumbnails One of the five becomes a Six-292.jpg   One of the five becomes a Six-296.jpg
cougarman is offline
Old 08-05-2015, 06:38 AM
  #199
Jon
Very nice, great craftsmanship.
Old 08-05-2015, 06:39 AM
  #200
RG.
We are going to try it at the 2" higher location, but we have a set of 1.5 and .5 spacers ready.
