One of the five becomes a Six >
Old 04-05-2016, 11:23 AM
  #311
mmb
Originally Posted by ICDEDPPL
That's a funny "small er" cam that keeps pulling past 6500. The 651 only gains 18hp past past 6000. It's done at the rpm that I run at.. At least that's one thing that was right in these Choo Choo cluster **** motors
My cam is a little smaller on duration, little larger on the lift. Could be several things keeping the engine from making power, unstable valve train, heads starting to go sonic, not enough carb. Doesn't always have to be the cam. But yes mine made power all the way to 6500.
mmb is offline
Old 04-05-2016, 11:49 AM
  #312
KAAMA's Avatar
Based on the past several years, I think it's pretty much common knowledge by now that a Whipple has the advantage over a Roots---it looks to have proven itself.
I know that when my builder had finished a long run on his dyno with a hard pull at the end that you could lay your hand on the blower case of a customer's Whipple and it would be cold to the touch. The Air Intake Temps are much cooler with a Whipple....that's at least one advantage of the Whipple vs a Roots.
KAAMA is offline
Old 04-05-2016, 04:49 PM
  #313
Originally Posted by Zero Patience
Chief really built some power into it . The whipple 8.3s are bad ass, it easily pulls the 17.5 x 34 5 blade merc cleavers now to 55-5600. Ran upper 90s easily, to rough to hang it out.check out the t shirt
That's some monster diameter u boys are runnin at 17.5. Keep the update posts coming, great project/thread and has been a joy to follow since the start. Any porpoise issues with that diameter over 90mph? I had 17" diameter on last summer on Old School and at 5400 was turning 97 on gps and had to go down in diameter or she wanted to literally jump out of the water so no way to open it up to 61-6200rpm safely...long way to go yet, needless to say, props redone this winter and waiting to try again when the pond thaws out.
38Raptor is offline
Old 04-05-2016, 05:06 PM
  #314
What rake angle are you running?
kvogt is offline
Old 04-05-2016, 05:21 PM
  #315
I don't remember....seems so long ago (last summer). BBlades boys fixed them up so we'll see what happens this summer when they get bolted on...don't want to high-jack and will get another thread going later.
38Raptor is offline
Old 04-05-2016, 06:11 PM
  #316
cigrocket's Avatar
I had 17.75 x 32 by BBlades on my straight bottom gun before I sold it, of course they were only 4 blades. You are definately making some power. Can't wait to hear the results. I was making somewhere near 900 HP at 5500. Boat ran 97 GPS with x dimension to the moon.
cigrocket is offline
Old 04-05-2016, 06:42 PM
  #317
Received 4,567 Likes on 1,315 Posts
Kvogt liking this.. that`s rich!
ICDEDPPL is offline
Old 04-05-2016, 09:38 PM
  #318
Zero Patience's Avatar
We both run 15 rake, the fuel was and is 93 unleaded, ethanol. Pump gas. We will put the video up of the Dyno . On our run last Friday the whipples were wet with condensation, and cold to the touch.
Zero Patience is offline
Old 04-06-2016, 06:54 AM
  #319
Zero,
Are there any advantages when running the whipples in relation to octane ratings? I would assume that detonation has more to do with the cylinder head design and hotspots inside the engine/combustion chamber/ cylinder (also a relation to intake temps).?
I.E. - "I can safely make 50 more hp at the same octane rating, compression ratio, # of static boost with the Whipples". Or maybe is it that they are just more efficient therefore yielding a better average horsepower under the curve, and possibly a higher peak. Or can you actually run additional/more boost everything else being equal. Does my question make sense?
(I may have answered my own dumb question....)
frickstyle is offline
Old 04-06-2016, 08:27 AM
  #320
mmb
You put new engines in?? Or are those N/A motors running that strong?
mmb is offline
