Crap start to my season
A little update:
Head gaskets were the problem. Since the heads are off now, going to do the valves regardless. Over the winter, I will most likely do the other motor so both top ends are gone through.
Good to hear and good plan.
Head gaskets banged up plug? Any pics? Or was plug melted?
I would also make sure you have inconel or equivalent exhaust valves...
Sounds like te mechanic is a good one from the posts so I am sure he will steer you in right direction and just not looking for a pay day.
I am not sure how you cannot notice a dead or near d&d cylinder let alone a few... That engine had to be down on power...
Head gasket is what started the problem from what I've seen.. Another reason to do the heads is the plug. The plug also looked rusty so thinking water go to it. The plug still had the 90 degree end on it, but the center electrode is what was gone so I not sure on the details.
Its the craziest thing I've ever seen. Looking back, the only thing I noticed was my top speed wasn't the same, but thought it could have been the load and when I was idling in a slow zone, the right motor was at a lower RPM and I had to throttle it a bit more to get the 2 to match. When on plane, the RPM's matched. I couldn't explain it if I tried. There was nothing else showing signs of a cylinder down..
Yea, but when I dropped a cylinder in a car I noticed the idle was rough and backfiring etc. Just thought it was odd that on this one I heard nothing out of the ordinary and didn't even think about that with the symptoms I listed above... Now I know better haha
When you lost power, were you at cruise or idle? I still have my mind wrapped around how I could be matching RPM's at speed, but running 6mph in slow zones I saw the difference.. I just need to change my mindset and be thankful that I should be on the water next weekend haha
Sorry to hear that, its amazing what can cause the symptoms, if the head gasket was going and a little water was going in that would cause that cylinder to lean out. happened when my first set of aluminum heads rotted. I would tend to think you caught it just in the nick of time before something went bad and hydro-locked it, could have been much much worse. Dave is the kind of mechanic that will always lean to the be "cautious and prepared" side. as much as this sucks it could have gotten worse and been a lower end redo as well.
Trust me..I was worried until I got that phone call saying the lower end looked good. After seeing the head gaskets, it definitely was about to get really bad. The good news is that the heads should be done Saturday and Dave will have me ready for the following weekend. If the weather is nice, Saturday I'll be cleaning and getting ready for the water and most likely head out for a bit and run some old fuel out. Then Sunday I'll for sure be out all day...
