Thinking about an upgrade (newer faster cigarette)
Nice boat but I think I have landed on it going to be a Cafe Racer. Although I need to sell my boat for multiple reasons. First to move forward to the next boat. Second to free up some space and third is the cash is always nice. Any thoughts to my approach to selling it parts, as is, or turnkey. I leaning towards just taking the hit and selling as is!
to each there own I guess…good luck in the hunt!!!
Received 3,230 Likes
agreed. I’ve owned both. Guns a better all around boat. Cafe is fine. No problems. But a gun is a better boat.
and a
cafe doing 90+ with 750 hp? Meeeeeeeeeh, I’d like to see that.
I agree with tank. I would think a 600hp Cafe is going to net you about 75-77 on Bravos.
750 maybe puts you in the low to mid 80’s? I could be wrong, but I’d take both the 750 and the 90 with a grain of salt.
Thanks again to all. My reason for 35 or shorter is simple that I don’t use the cabin, my dock can’t accommodate anything more, and my thought was a longer boat is going to be slower.
Why would a Top Gun be faster than a Café Racer assuming the same power and drives?
I always thought of speed as function of hull displacement. My 1981 33’ displaced a lot of water because it is wide and it has a low drive height. Super safe rough water boat but not fast.
What are the difference between the Top Gun and the Café Racer that make the Top Gun faster?
I believe the Cafe Racer is a straight bottom hull and the Top Gun is a stepped hull. Given the same hull, power and weight otherwise, the stepped hull will run considerably faster, due to ventilation and reduced wetted surface.
Thanks. Brad.
Not an expert but my understanding from what I’ve read is that the Top Gun’s hull is better balanced and more efficient than the Cafe. I’m sure others with more knowledge will chime in.
All good. I googled the two hulls, and all the images of TGs appeared to have a couple steps. Google very often gets it wrong, though, as witnessed by the fact that there were several TGs, and labeled as such, that came up in my search for Cafes.
Carry on....
Thanks. Brad.
It’s fairly common knowdledge that top guns with equal power and drives are faster than cafes.
the TG bottom has a notched transom. The cafe does not.
All new knowledge for me, so thanks to all! How significant is the difference. Are we talking a couple miles an hour, 5, or 10 MPH if both boats have the same power and drive.. I think I will be need to get a Cafe Racer for multiple reason but I may need to make sure to have good power.
I am assuming that the Cafe Racer is a good boat just not as fast as the Top Gun.
