My Resto Project
Old 10-17-2011, 06:49 PM
  #91
aex
aex's Avatar
Originally Posted by bulletbob
We were having this discussion last night while plumbing secondary fuel systems in a Doug Wright. For the money go with the intergral tanks, just build a removable lid for the tank for service. I suggested blatters but, they are pricey and from what I was told they only last a few years before they break down.
The money wasn't right for me to do the trade. It was a Doug Wright also. Keep us posted. Bob
The Wright boat has integral tanks ?
aex is offline
Old 10-19-2011, 07:41 PM
  #92
aex
aex's Avatar
Default Peter from Skater. Who else ?
After browsing the Skater forums I finally decide to give Skater a call . I'm quickly referred to Peter and open the conversation with " Hi , I'm redoing an old Chris Cat and am calling to get advice on building in hull fuel tanks for this boat" . His reply , " Sure , but I'm with a salesperson , give me your name , number and I'll call you".
I'm thinking he just gave me the flick , however two hours later my secretary tells me there's a gentleman , Peter from Skater boats on two for you .
Wow , here we go ! Peter in detail described the process and materials involved . When I asked about tank fittings he even offered to send Skater fixtures so I wouldn't have to go through the process of having them made from scratch . He even actually remembered my boat and mentioned some names from my era that brought back good memories .
Peter , I can't emphasize how grateful I am for you taking time out of a busy day to advise me .
Thank You .
aex is offline
Old 10-19-2011, 08:07 PM
  #93
Biggus's Avatar
Thank You .
Class act. Refreshing.
Biggus is offline
Old 11-19-2011, 08:21 PM
  #94
aex
aex's Avatar
Engines at machine shop , heads are done , drives apart .
Hull going in two weeks for fuel tanks . I'm still debating the cockpit .
aex is offline
Old 11-20-2011, 02:19 AM
  #95
Any pics of your fuel tank project aex ?
Have same issue, need to build new fuel tanks.
HAve a plan to make two separate aluminium tanks in a row
and connected them together via big rubber pipes (one upper
part of tanks and other down side of the tanks).
plan is insert new tanks inside of old tank by pulling
them inside in cabin area.
What do you think this plan good / bad or are there
better way to do this ?
picture: older tank are cut open in cabin area, place to insert new tanks in.
shootitup is offline
Old 11-20-2011, 11:14 AM
  #96
aex
aex's Avatar
No photos yet . I'm having the tanks built into the hull as Skater does using the appropriate materials . This will add structure to the boat without a major weight difference .
I've seen one Chris Cat where they cut the bulkhead in front of the tank yanked them out and slid the new ones in .
Make sure you have the tanks under the cockpit , those forward tanks will kill the cg .
aex is offline
Old 11-20-2011, 11:30 AM
  #97
aex
aex's Avatar
Default Unexpected setback
Opened up the drive drive yesterday and found this . The drives have been sitting since '93 . These are # fives . I do have two pairs of fours but back in the day I was cracking the # four lower gear cases between the propshaft and cavitation plate . After I switched to fives all went well .
Those fives were fresh when I pulled them so I presume some seal allowed water in , too bad I didn't drain and refill them back then .
I'm sure you are all aware the expense of a project of this magnitude is immense . This mishap probably just added 10k to the restoration . Anyway no tears , I'm over it .
aex is offline
Old 11-20-2011, 11:55 AM
  #98
Well I think a can of WD 40 will get rid of that brown stuff.....
Have Galen at Speedmaters clean them up.
Wannabe
wannabe is offline
Old 11-20-2011, 12:01 PM
  #99
aex
aex's Avatar
He did my fours way back . Good organization and good service . I'll give him a call to get a guesstimate .
aex is offline
Old 11-20-2011, 12:08 PM
  #100
aex
aex's Avatar
Wannabe
BTW , I think I almost bought your Chris when it was on the market a few years ago . Was it in New England when you acquired it ? It looked like a really great , clean boat . Please post some photos .
Back then I was trying to avoid the rebuild of this old racehorse .
aex is offline
Quick Reply: My Resto Project
