Bringing some life back to a old 10 meter :D
#41
Pirate of the Chesapeake
John jr
#42
We took that boat in trade for a 36 spectre he took all the power 1000s 4 speedmasters with boxes and installed them in the cat,I think it was around 2001 i had the hull surveyed and it checked out ok the only thing he noticed was the bottom sounded different on one side the previous owner had installed 1 new tank and maybe used different foam,so we decided to install a new tank on the other side the center stringer looked fine,we installed a new transom the stringers were fine we installed the bravos with rebuilt merc 500 installed hydromotive 26 4 blades,took the boat for the first sea trial and was amazed how well it ran had and old norskog speedo showed 86-88 mph probably gps speed 80-82 handled great was the nicest riding 10m i have been in
#43
John jr
#44
Well, got all the hardware off the back, in the process of sanding it all down, some things I do not like about it, but I guess that is what happens when a boat has been done for over 10 years. It has been to hot an humid to do any sanding or glassing, so I just held off. I did get 2 gallons of white IMRON, should be plenty to do from the rails down to the first strake. Will get some pics up soon.
John jr
John jr
#46
Finally after getting the transom assemblies off and the trim tabs and steering off must have used crazy glue.The finish under the tabs was all messed up ground out the bad stuff re glassed and filled.Used 3-M premium filler as per glassdave he does know his stuff .That stuff is great to work with.What a job.Now the complete hull is ready for primer.Laid off a few weeks to hot to work.So back on it now.Next will be paint using Emron on hull sides and deck.Just a little update.JOHN SR
#47
Well dad was able to get over today to get a coat of primer on the transom, about 1/2 up each side. Looking better already.
John jr
John jr
#49
Thanks. We are shooting for spring time to be finished. Not in a big rush. Yes we have a pair of 555 dart BBC's that are going in it. They were orig going in the 32 fever, but decided they would be better suited in this, so stock big blocks went in the 32. Will try to getsome pics up in a bit
John jr
#50
Was able to get one side done, still have some to d on the other side, then some block work. Hopefully will have it in paint in a few weeks. Also will have some engine pics up
John jr
John jr
