Manta 28
That's what I was thinking. With a straight edge from the bottom of the boat it comes to just below the bottom of the water pickups, so they are def too high. The nose cone is in the sweet spot right under to bottom of the boat. I will post pictures of before and after with the straight edge to the water pick ups. Water psi now is between 10-12. I would like to see 15-20 at higher rpms.
[https://www.youtube.com/watch?v=iD-t..._gdata_player][/YOUTUBE] Scott Duval driving Damn Manta 28 ft Manta. 1991 Chicago lapped half the field and won the race. Damn Manta. Courtesy of Scott Duval
Gorgeous! Wish I would have seen this post earlier. If you glue up/close off the top half of your stock intakes you'd have been done. Have done it successfuly tons of times.
I don't want to jinx you but every heavy Vee bottom O/B I've added nose cones to has slowed down and forced me to run full up trim to fly the bow when I didn't need to previously.
Where are you/boat at? Pix's look like Fla??
Regardless, best of luck on a gorgeous rig. And, more pix's please.
