help identify this boat
Hello new to the forum. I've been searching for a while and have found what I've been told is a 27 foot 1968 Magnum. I was hoping someone on here could help me out on identifying it. Or if there is a hull identification some where on it. I have some photos I could send you. Having trouble trying to post them.
original color was yellow with "Smoker 1 S-33" down the sides
John
John
I had this responce from another forum member
"John,
I'm pretty sure this is NOT a Magnum. Sorry.
1) The strakes are different leading up to the bow. Check pics of the next two post here on the Magnum forum.
2) About 12" down from the deck the Magnums have a distinct "chine line" running the length of the hull-your boat does not have this.
To me, it looks more like a Formula. If you post this on the Classic Forum, "Brownie" use to work at Magnum- and a dozen other companies, and will be able to give you more information.
Good Luck!
Bob"
"John,
Good Luck!
Bob"
