magnum marine 25
The following 4 users liked this post by boostbros:
I've done a number of re-powers, so I hope sharing this helps you If you are going to repower it yourself, the I/O would be the simplest. The outboard will likely require a different X Dimension, so if you haven't done a conversion before, you would have to experiment (guess) with the X-Dimension. The impact to CG (center of gravity) also needs to be taken in account. In addition, the rarity of a 25 Magnum means you have few, if any people who may have done that conversion, so likely no one to provide you guidance. A good rigging shop could do the conversion, but it depends on your budget.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
Thanks, Barry
The following 2 users liked this post by O.C.Barry:
larslindroth (09-29-2022), TrippM (09-26-2022)
keep it I/O
