Go Back  Offshoreonly.com > Owners Forum > Cobalt
Cobalt 343 >
Cobalt 343
Cobalt 343
Old 12-09-2007, 09:10 PM
the 343 has a 24.5 degree deadrise single stepped bottom
stainless is offline
Old 12-09-2007, 09:32 PM
Forum Regulator
Sydwayz's Avatar
Received 1,263 Likes on 551 Posts
Per:
http://www.boatingmag.com/article.as...1&print_page=y
Dry weight is 11,565 lbs. That's a HEAVY boat. I bet the 43' Nortech weighs close to that.
They also only list the maximum cabin headroom as 4'11".
I read they only built 1 Cobalt 343 w/ 575s, and it was for one of the HMFICs of Cobalt. True?
(The current Cobalt website only has the 323 listed, and that has a 22* deadrise.)
Black Thunder IS the way to go if you can swing the (big) logistics of the 43'/46' boat.
For comparison; I am 6'2" and I can stand up with my head tilted to the side to use the head in the 33'/37' AT.
Sydwayz is offline
Old 12-09-2007, 09:36 PM
Originally Posted by Sydwayz
Is there anywhere to get accurate specs? The website only has the 323 listed, and that has a 22* deadrise.
http://www.boattest.com/boats/827/specs.aspx
pasquesi is offline
Old 12-09-2007, 09:37 PM
those specs are accurate i own a 343 right out of the brochure you can also go to cobaltboats.com and look under previous spec sheets/brochures to bring the info up
Old 12-09-2007, 09:40 PM
once on the website go to download library , then owners manuals for the boat and year desired
Old 12-09-2007, 09:42 PM
you can also check brochure back issues for model and year desired all specs are there
Old 12-09-2007, 09:48 PM
i know that ocean performance sold one with 600's however the limiting factor is the xr drives if you put too much power to them you start breaking things if you search the forums you will find that cobalt apparently had problems getting enough air to the 600's overheating and what not.. the 525's run great!
Old 12-09-2007, 09:58 PM
heavy yes but this combined with the sharp deadrise yield a very nice ride in the slop for a 35 ft boat. for comparison my friend has a 35 donzi with the same power/drive setup that will run 92 in calm conditions throw in some 4-5 footers and i walk away from him
Old 12-09-2007, 11:34 PM
Forum Regulator
Sydwayz's Avatar
I found some better Google results on specs the more I looked; BUT the specs vary from site to site (weight).
I think Cobalt's are awesome boats; no need for anyone to be defensive.
pasquesi asked for any input; and when he said he was going to run Lake Michigan, that's when I mentioned that he'll probably be more comfortable in a traditional offshore boat rather than a "gentleman’s high-performance boat .... posh dayboat offering".
I forgot to mention earlier that the 38' Powerquest and the 38' Donzi ZX are also BIG cabin and cockpit boats, as well as the Baja .38 Special.
Sydwayz is offline
Old 12-09-2007, 11:55 PM
Forum Regulator
Sydwayz's Avatar
ive got one for sale w/ 24 hrs and 525s warranty till sept 2012 pm me if interested ps this one runs strong 80 mph full of fuel with 5 big guys on board
Where is your boat advertised? I'd love to see some pics.
Sydwayz is offline
Quick Reply: Cobalt 343
